RCU Forums - View Single Post - Reciever Will not charge on Field Charger
Old 01-06-2010 | 06:18 AM
CGRetired's Avatar
CGRetired
Default RE: Reciever Will not charge on Field Charger
Technically, you don't charge the transmitter nor the receiver. You charge their batter packs.
Try removing the battery pack from the TX or disconnect the receiver pack from the receiver and try charging them directly. If that does not work, then I would check out the charger to make sure it's working properly.. fuse opened or something maybe?
CGr.
