RCU Forums - View Single Post - Official Hyper 8 Thread
Old 01-06-2010 | 09:40 PM
  #1749
xjqkz's Avatar
xjqkz
Default RE: Official Hyper 8 Thread
ORIGINAL: 46u
ORIGINAL: xjqkz
ORIGINAL: 46u
I have over 10 gallons on my Hyper 8 and about 4 on my 8.5 and never had a problem with leaking on any of my diffs. I do replace the seals about every 5th time I go into them. Are you sure it is the o-ring under the crown gear ro the ones on the out put shafts?
I have so much RC stuff I am going to sell my Hyper 8 pro as a roller with some NICE up grades.
It is the orange o-ring (in the center diff 6 bevel gears) that stays visible after you screw everything up (not laterally )
Whats a good right height front and back for hyper? I've mine set at: front= 28mm and rear=36mm
What weight do you run in your diffs?
Like I said never had a problem with mine leaking and I use to change my diff oil after every two weekends of racing. A lot of variables in set ups. As far as ride height I ran mine where the A arms where not quite horizontal pointing down a little around 33mm give or take. Diff oil would vary on track conditions but a good start is front 5k, center 7k and rear 2k or that is what I used as a base line.
Do you run 7k center in the 6 gear spider diff or is it the regular diff w/ 4 gears?
