RCU Forums - View Single Post - Beam mounts
Thread: Beam mounts
Old 01-08-2010 | 08:36 AM
DarZeelon's Avatar
DarZeelon
Default RE: Beam mounts
Bob,
This engine has a crankcase width of 60 mm.
For some reason, Tower's tech dept does not seem to understand that this is the most crucial dimension of the mount...
The the internal span between the bearers, is what determines if a mount will fit a certain engine, or not.
[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXATG7&P=7]This mount[/link] has what Tower calls a 'mounting width' of 60-75 mm, which is what I believe to be the crankcase widths if can bear.
If this is correct, it will suit your MVVS 40 cc engine.
But I believe you should ask them this question, before buying it.
