RCU Forums - View Single Post - Help for making a plug from foam
Old 01-08-2010 | 09:58 AM
Hustler58's Avatar
Hustler58
Default RE: Help for making a plug from foam
ORIGINAL: julianp4
Hi
Were there any more ideas on this one? I am trying to produce a couple of small moulds for football arials but cant get the packing tape to work well.!!!
help???
If you are using epoxy you don't have to put anything on the foam. Just lay your glass and resin right on the foam. If you are using polyester than you have to be real careful. I would take spray adhesive and aluminum foil. Spray the foil and apply to the foam. The foil will have small wrinkels but they will not be seen through the glass cloth. Then wax and put a heavy coat of PVA. Butch
