RE: 3D PROP SELECTION
With a plane that overpowered not sure a different prop is going to help. I have run 18x8's and 20x6's on the OS160 depends on ground clearance. I did have that same problem and fixed it by increasing the resulution of the throttle trim on the TX. You may or maynot be able to do this depends on your TX.
