RCU Forums - View Single Post - Another Motor problem ?
Old 01-11-2010 | 12:35 PM
VooDooModified
Default RE: Another Motor problem ?
Yeah, you could probably fit one in there but it wont run worth a darn. piston sleeves are matched to the inside of the crank case. So the ports on the sleeve matcgh the channels in the case...while another sleeve might fit, the flow will be off. so basically, dont do it.
