Car Nitro & Gas Engines Discuss all aspects of Nitro and Gas rc car engines here!
Another Motor problem ?
Old 01-10-2010 | 03:21 PM
Default Another Motor problem ?
Hi guys agin, I wanted to know if all of the same size motors take the same kind of sleeve ? You know piston & sleeve !
I have a 4.6 motor by HPI and wanted to know if I could use another .28 motor sleeve ?
I know I know, to you it's a dumb question but I gotta know ?
Old 01-11-2010 | 12:35 PM
Default RE: Another Motor problem ?
Yeah, you could probably fit one in there but it wont run worth a darn. piston sleeves are matched to the inside of the crank case. So the ports on the sleeve matcgh the channels in the case...while another sleeve might fit, the flow will be off. so basically, dont do it.
