RCU Forums - View Single Post - Designing a new pattern model
Old 01-11-2010 | 03:17 PM
  #127
Alex Voicu
Default RE: Designing a new pattern model
It's not liteply, it's 1.5 mm regular plywood. Liteply usually comes in thicker sheets; minimum thickness of liteply available here is 4mm, with the same weight as the plywood i used.
Balsa sheeting is also 1.5 mm.
