RCU Forums - View Single Post - SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION
Old 01-12-2010 | 01:46 PM
  #158
tkg
Default RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION
If your balance problem is the rod weight, then try using an UNBALANCED prop. You added crank pin weight so with the engine at TDC set the prop so that the heavy blade is at the bottom. Just see if it helps, if it does then unbalance your prop hub.
