ORIGINAL: OttoKranz
Hi all,
also in my viper there is a problem of alignement of the mounting rails of the turbine. I've used two wires across the middle of the rear hole of the fuselage and all the way through the middle of the central air intake and than out from the two front intakes on the fuselage. I know the best way should be the alignment with the wings but is too difficult and this way should be fine. I had to make to wooden wedges....
look the inclination!! Now I think I'll only have to raise the turbine vertically less than 1 cm because the aluminum wings attached on the turbine are not (as usually) in the middle of the turbine.
It's late here in Italy [sm=confused_smile.gif] so I'll post some pictures that speak better than me.
Did you have the same problem? Any suggestions more?
Ciao
Alessandro
dont use the intake for alignement , use the pipe as reference to the turbine!
a lot seems to have this problem
