ORIGINAL: DelGatoGrande
ORIGINAL: Matt Chapman
Will an incidence + or - have an effect on the pitch of the plane based on power in flight? ...
Hey Matt
Yes it can have an effect!
like in prop planes we must fine tune the up down thrust of the engine.. same think in jets.
its like you having a vector thrust set up whrong...
start seting a degree lazer meter to zero on the
wing ...then check engines mounts and pipe..
..but if Matt Chapman enjoy fly this toy untill now..then it needs no corection
forgive my poor english
Besides the problem of the thrust line another problem could be the heating of the tube. With the incidence of my mounting rails of the turbine the bottom of the tube will be much more hot the top and we are speaking about many degrees... am I becoming paranoid? [&:]
Alessandro
