ORIGINAL: ntyhobbies
Hi there,
I have a Frank TJ67 turbine and the thermocouple has failed........the original thermocouple has three wires going to it. Alternative thermocouples only have 2 wires so does anyone know if this will work with the 2 wire thermocouples? My ECU is a Projet Hornet with optical rpm pick up.
Hope someone can shed some light on this problem for me.
Cheers,
Nigel
why dont you measure the resistance between the cable?
i think one is for shielding only Green/white and?
your the guy who makes that wonderfull oven with the turbocharger on top?
