RE: Bearing Sets - Boca, Acer, Avid.....
I have been running Boca Bearings for a while now and have had great luck. Boca does have the $1.00 a bearing 10 packs for economy and also any other types up to full ceramics,, so you can choose what fits your budget. The support is very helpful and they also have their own line of prelubes and greasesthat work great. As far as clutch bell bearings go I have gotten up to a gallon on one set, yes after a race day I will clean them and put a drop or two of their Lighting Lube and they work great, you can also order them with grease removed if you like, even though I run them with the greaseinIhave had no issues.
