RE: Engine Trouble
That is the pinch on a regular ABC engine. Some engines are really tight.
You can put another gasket on the glowplug to reduce compression a bit and heat the engine with a heat gun prior to running. After a few tanks the engine will be run-in and you won't feel such a tight pinch.
