Engine Trouble
Old 01-16-2010 | 10:45 PM
w8ye's Avatar
My Feedback: (16)
Default RE: Engine Trouble
OK,
The screw on the side is the low speed mixture screw
Before turning that one, lets get the high speed set first which it is down inside that tube.
Old 01-16-2010 | 10:57 PM
proptop's Avatar
My Feedback: (8)
If however the low speed mixture is too rich (and that is typical of factory settings with these type engines ) it can cause flooding or partial flooding which can make the engine very difficult to turn over. (and it's very hard on the pull start mechanism )
The spitting and sputtering from idle through transition to higher r.p.m. means it's loading up...and the low spd. mix needs leaning out a bit. Turn the low spd. adj. in CW 1/8 turn at a time to sneak-up on it.
