RCU Forums - View Single Post - Engine Trouble
Old 01-16-2010 | 07:34 AM
spaceworm
Default RE: Engine Trouble
Take the plug out and then see if it will turn over. If so, then it is just is a high compression engine. If not, either you left out a head shim causing the piston to hit something, or the screws were not tightenbed equally cocking the cylinder and jamming the piston.
