RE: How does torsion suspension work?
You'll have to check out different steel rods and select one that will give to 45-60 degree twists without breaking and return back to the original point. . Don't forget that end has to be solidly mounted in the opposit side of the tank. Not going to be an easy job. Do you really need the torsion bars? [:-]
