RCU Forums - View Single Post - AEROWORKS P51 Build
Old 01-18-2010 | 12:46 PM
Condor060's Avatar
Condor060
Default RE: AEROWORKS P51 Build
<p class="MsoNormal" style="margin: 0in 0in 0pt"><font size="3" face="Times New Roman">I started with the radiator because it was going to be the hardest to cover given the complexity of the curves and I would waste very little Flite Metal by screwing this up. I have a couple of blemishes but nothing I can&rsquo;t fix. I also made a few small panels on a piece of hardwood to practice on and it did great.</font><font size="3" face="Times New Roman"></font></p><p class="MsoNormal" style="margin: 0in 0in 0pt"><font size="3" face="Times New Roman">We used diluted Zpoxy finishing resin with acetone around 20%.</font><font size="3" face="Times New Roman"></font></p><p class="MsoNormal" style="margin: 0in 0in 0pt"><font size="3" face="Times New Roman">I have two other guys helping me with the project and we are going to start laying down FM this week. Everything has been primered, filled, and sanded and we are doing the final prep work.</font><font size="3" face="Times New Roman"></font></p>
<font size="3" face="Times New Roman">We are using an orbital disk sander set at 40 lbs air pressure with a 600 grit wet before priming and 1000 grit wet to get our final surface. Getting everything level and square is all done by hand.
I have completed some FM on the cowling but can't go any further until I receive the exhaust from Keleo.</font></p>
ID:	1358939   Click image for larger version
ID:	1358940   Click image for larger version
ID:	1358941   Click image for larger version
ID:	1358942   Click image for larger version
ID:	1358943   Click image for larger version
