RCU Forums - View Single Post - e-Neptuno
Thread: e-Neptuno
Old 01-18-2010 | 08:57 PM
Derek.Koopowitz
Default RE: e-Neptuno
I then marked the screw holes with a fine point marker and used a heated pin to "burn" the servo mounting holes in the plywood brackets. In went the servo afterwards with the screws. Next step was to put the control horn in - I used the supplied bolt and associated hardware. I used a little Loctite on the threaded rod to ensure it stayed in place without backing out. The next step was to make up the control rod using the supplied ball link clevises. Everything is the right size and no cutting was needed. The only additional time taken was to ensure the rod was the right length and the stab was "flat" without any up/down trim.
Pictures are as follows:
1. Servo screw locations marked
2. Pin used to "burn" through the plywood to ease the servo screw access
3. Pin is heated
4. Holes made using the pin
5. Servo now mounted
6. Control horn for elevator
7. Partly screwed in
8. Screwed flush with the top of the elevator
9. Mounting the underside of the control horn
10. Adding Loctite to ensure the bolt doesn't move
11. Hardware mounted on control horn
12. Ball bearing part of clevis mounted
ID:	1359234   Click image for larger version
ID:	1359235   Click image for larger version
ID:	1359236   Click image for larger version
ID:	1359237   Click image for larger version
ID:	1359238   Click image for larger version
ID:	1359239   Click image for larger version
ID:	1359240   Click image for larger version
ID:	1359242   Click image for larger version
ID:	1359243   Click image for larger version
ID:	1359244   Click image for larger version
