RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle
MicroD, did the front Fork upgrade (oil filled Gold one) work better than the stock Forks ? How much better does it seem and is it worth the upgrade ?? I probably know your answer but before I go and order one (back order) would like to see if it's a must have. I still have a bit of head shake with the Dampener setup but not planning on doing over 30 or so offroading. I got my thrills on road hit 44 mph on 3s lipo so i am satisfied with that !! also what 3s lipo will fit in the battery box (I am using a Losi 2600mah 20c #LOSB9869) and only get about 7 minutes tops out of it,and it just fits. What else could I cram in there or what Lipo do you use ??? Still running all stock electronics with no problems at all.
