RCU Forums - View Single Post - e-Neptuno
Thread: e-Neptuno
Old 01-22-2010 | 01:42 AM
Derek.Koopowitz
Default RE: e-Neptuno
I don't know why my picture uploads are coming out HUGE - sorry about this... I've tried at least 5 times to fix this and I can't.
Continuing with the rudder installation, cabling and servo...
The weight of the rudder is 56g and the control horn and assorted fittings are 6g. The rudder cable and clevises are 10g. Since the rudder is removable there are 2 set screws that can be removed from the rudder - one on the top and one on the bottom. I removed the top set screw so that I could get the piano wire in from the top. I also threaded the rod through the rudder and mounted the fittings. I used Loctite to ensure that everything will stay together. The overall length of the control rod is much larger than the servo wheel that I will be using - at least by 15mm or so. All the fittings and horn ends were mounted.
Attached are the pictures...
1. Rudder weight
2. Rudder horn control rod and fittings weight
3. Rudder cable weight with clevises
4. Removing the set screw from the top of the rudder
5. Set screw
6. Screwing the rudder horn control rod into place
7. Rudder servo wheel and the control rod - you can see the increased length of the rod
8. Putting Loctite on the rod to hold the fittings in place
9. One fitting installed
10. Both fittings installed
11. Clevis connectors installed
12. Another view of the connectors in place
ID:	1361359   Click image for larger version
ID:	1361360   Click image for larger version
ID:	1361361   Click image for larger version
ID:	1361362   Click image for larger version
ID:	1361363   Click image for larger version
ID:	1361364   Click image for larger version
ID:	1361365   Click image for larger version
ID:	1361367   Click image for larger version
ID:	1361368   Click image for larger version
ID:	1361369   Click image for larger version
