RCU Forums - View Single Post - VectorFlight 300s, anygood?
Old 08-27-2003 | 03:31 AM
  #63
David Cutler's Avatar
David Cutler
Default VectorFlight 300s, anygood?
Originally posted by Scale Dreamer
You have also referred to brass inserts on the belly pan instead of screws. Can you ellaborate? Are you talking about "bling" type threaded inserts and then using a screw into that? Any pics of this detail?
Hi John,
I used the standard method to make the wing joints. I would suggest you sand them a little at a time to ensure a really good fit. Actually, it's quite hard work as the ply is so hard, but it's worth it.
To mount the belly pan and cowl, I use brass inserts:-
http://www2.towerhobbies.com/cgi-bin...?&I=LXK030&P=7
- screwed into the firewall (for the cowl) or a piece of hard balsa epoxied inside the fuselage side (for the belly pan), and a short 4-40 steel bolt going through a washer and small piece of fuel tubing.
David C.
