ORIGINAL: smorlock
I would like to feel that someone wants my business.
Well I certainly do, and I can assure you that I'll do whatever I can to make you happy.
BTW The Giles and MX2 are out latest designs so they have the benefit of experience from all our earlier planes, they are very solid.
And BTW there is a feature that isn't obvious. These planes have two possible wing tube locations. One of them is in the scale low wing position, the other is position approximately in the center of the fuselage (vertically). I did this because some people prefer it to look scale, but the mid-wing actually flies a little better. This layout is similar to our Sukhoi which has the wing just slightly below center and the stabs just slightly above.
I think the mid wing also looks a lot better, at least on the MX2.
The photos below show the low wing and mid wing versions. The red/yellow "Breitling/Wild Hare" plane has the mid wing mounting, while the Red MX2 and the yellow/blue Giles have the wings mounted low.
Tom Fawcett
Wild Hare Hobbies
