RCU Forums - View Single Post - Wild Hare Electrics
Old 01-25-2010 | 09:25 AM
  #54
rctom's Avatar
rctom
Default RE: Wild Hare Electrics
ORIGINAL: STANG KILLA SS
BTerry
What servos are you using. I have one with the Power HD 2213 servos all around with dual elevator servo setup. The plane flies very eratic and does not let you fly with any confidence. It just feels like the servos are doing there job. If you get very aggresive with the elevator it want to roll over. Everything seem OK on the ground. I was sure hoping this was going to be a great 3D plane. I will be curious to see if you can get 12 minutes of flight time. That seems like alot for an electric plane of this size.
Where do you have your CG? I know that it sort of jumps around when the CG is too far back, it smooths out as the CG gets about 1/2" in front of the center of the wing tube. Try moving the battery forward 1/2" at a time.
12 minutes is not at all unreasonable using 3000+ mah batteries. I get 7 minutes and put back 2000 mah.
TF
