ORIGINAL: BuschBarber
There are no 3rd party 2.4 receivers. You cannot, for example, use a Futaba 2.4 Rx with a JR/Spektrum Tx. JR and Spektrum use the same technology, so you can use a JR 2.4 Tx with a Spektrum Rx and vice versa.
I believe that the DX5 is DSM. You can use a DSM Tx with a DSM Rx, but you cannot use a DSM Tx with a DSM2 Rx. You can use a DSM2 Tx with a DSM Rx. DSM is an earlier version of Spektrum technology. DSM2 is a later version. Be sure to check and see if the Rx you plan to use is DSM.
A Bind n Fly airplane comes with a JR/Spektrum compatible Rx. You could buy the same aircraft in a Plug n Play version, which does not come with an Rx and allows you to put in whatever Rx that is compatible with your Tx.
Sp I can use differrent name brands together as long as they use the same technology. IE: dsm to dsm or dsm2 to dsm2. How many types are there? 2? dsm and dsm2?
