RE: 75ax
The plane calls for a .60-1.00 2 stroke and it's flying weight comes in at an advertized 6-9 lbs, which is a wide range as 3 lbs can make a huge difference in a model this size. With the .75ax I guess I would expect it to be able to hover but maybey not pull out of it. Other than hovering the engine should perform well enough on other 3D manouvers.
So, which position are you in?
1) You have an engine and want a plane for it...
2) You have the plane and want an engine for it...
