RCU Forums - View Single Post - Vertigo II Build Thread
Old 01-26-2010 | 11:52 PM
  #104
KLXMASTER14's Avatar
KLXMASTER14
Default RE: Vertigo II Build Thread
1. Cut a balsa shim, and Hot Stuff it to the nose ring of the fuselage. Here I am using an otherwise useless piece of heavy C grain 1/16 balsa.
2. Slip the engine into the bay. Bolt up the backplate, and tack Hot Stuff the spinner back plate to the balsa spacer.
3. Now you can accurately mark/drill the engine mount holes. Shave off the balsa shim from the fuselage nose ring. Congratulations, you now have and accurate, neatly spaced spinner gap.
4. You are "old school", or just "old" if you still call CA glue "Hot Stuff".
ID:	1365408   Click image for larger version
ID:	1365409   Click image for larger version
