ORIGINAL: DukeStarhopper
Do you think that the materials in my kit are still usable?
YES
Assuming that the materials are OK, what is the best adheisive to use in attaching the balsa skin to the foam core?
Your choice. Contact cement (foam safe of course), Gorilla glue, epoxy... do some research and see which method makes the most sense to you.
Will the present 3M 77 spray work or how about the new white Gorilla glue?
See above.
Is there any difference in the foam used by Sig today compared to that used in 1983?
No.
