RCU Forums - View Single Post - Programming the Multilight mini lighting module
Old 01-27-2010 | 01:28 PM
Ragz's Avatar
Ragz
Default RE: Programming the Multilight mini lighting module
Hi Todd, I will see you on messenger... However, I just wanted to know what to do after you press both the sw1 and sw2 buttons?  Do we need to use both those leads into the rx?  The lights on  my setup are flashing and I cannot make the headlights stop flashing and stay ON.  Same with the nav lights.<div>
</div><div>My connection is as follows:  </div><div>
</div><div>Headlights 1 and 2 in series on channel 1</div><div>Headlights 3 and 4 in series on channel 2</div><div>Headlights 5 and 6 in series on channel 3</div><div>Green and Red in parallel on channel 4</div><div>
</div><div>With this setup, the 6 headlights are all working, but flashing, the green glows but the red is very DIM.. wonder if its defective or wrong connection.</div><div>
</div><div>This was done as per instructions provided.</div><div>
</div><div>Cheers</div><div>Anurag</div>
