 Programming the Multilight mini lighting module >
Old 01-27-2010 | 11:54 AM
Ragz's Avatar
Default Programming the Multilight mini lighting module
Hi, can anyone help me program this gadget please?
thanks
Old 01-27-2010 | 12:28 PM
lov2flyrc's Avatar
My Feedback: (24)
Default RE: Programming the Multilight mini lighting module
ORIGINAL: Ragz
thanks
Anurag,
Hit me on Messenger and I can walk you through your questions
Todd
Old 01-27-2010 | 01:28 PM
Ragz's Avatar
Hi Todd, I will see you on messenger... However, I just wanted to know what to do after you press both the sw1 and sw2 buttons?  Do we need to use both those leads into the rx?  The lights on  my setup are flashing and I cannot make the headlights stop flashing and stay ON.  Same with the nav lights.<div>
</div><div>My connection is as follows:  </div><div>
</div><div>Headlights 1 and 2 in series on channel 1</div><div>Headlights 3 and 4 in series on channel 2</div><div>Headlights 5 and 6 in series on channel 3</div><div>Green and Red in parallel on channel 4</div><div>
</div><div>With this setup, the 6 headlights are all working, but flashing, the green glows but the red is very DIM.. wonder if its defective or wrong connection.</div><div>
</div><div>This was done as per instructions provided.</div><div>
</div><div>Cheers</div><div>Anurag</div>
Old 01-27-2010 | 04:04 PM
F106A's Avatar
Good luck trying to program the lights.
I've spent numerous hours, and lots of e-mails back and forth with the designer in Germany trying to program them with no luck.
Finally I just gave up, they're not going to work and it's just not worth spending any more time fooling around with it.
BRG,
Jon
Old 01-27-2010 | 04:11 PM
lov2flyrc's Avatar
My Feedback: (24)
ORIGINAL: F106A
BRG,
Jon
Hi Jon,
I walked Anurag through the programming, I would be happy to do the same for you. Additionally, if preferred, you can simply send the module to me with your program requirements and I would be happy to program the settings for you.
Todd
Old 01-29-2010 | 01:28 AM
Ragz's Avatar
Hi Todd,
Thanks for the assistance the other day.  However, I would really need some more guidance on programming this device.  Its actually not very intuitive to programme im afraid.
Cheers
Anurag
