RCU Forums - View Single Post - Tailwheel setup when converting GP Big Stick to Tail Dragger
Old 01-29-2010 | 12:07 AM
DenverJayhawk's Avatar
DenverJayhawk
Default RE: Tailwheel setup when converting GP Big Stick to Tail Dragger
ORIGINAL: out of money
I got my 60 size set up with a tail wheel but no control rod to it yet. I have lightweight 5'' main wheels and I'm moving the battery back as far as possible. Also has an OS 90 on it. I'll try to get pic of tailwheel bracket with 1.5'' tailwheel posted soon.
Here is pic of tailwheel temporary setup without control rod and maybe small plywood piece added for support, I might due a separate servo to.
At that location, if you want controlled steering on the tail wheel, I'm guessing you will likely need to add another servo.
