RE: Ultracote
Calibrate your covering iron. This is most important. Use a meat thermometer or such and figure out where 200-230F and 330F are on you dial. Then use the lower heat to apply covering the best you can. The when finshed with that part(fuse, wing,etc) go back over with the higher temp and take out wrinkles and shrink as desired.
