RCU Forums - View Single Post - My HE Leopard 2A5 modification to HL
Old 01-30-2010 | 01:52 PM
beachboy
Default RE: My HE Leopard 2A5 modification to HL
Found the Leo again, and tought I could do some adjustment to it.
Replaced the last plastic with metal, so the gears are now all metal. Refitted the gears to the metalplate so they are more correct adjusted to each other, and the sprocket now is closer to the lower hull. Hopefully the tracks will run smoother now. Will also use som return rollers for the tracks.
Got some return rollers from a HL M41 walker bulldog I think I'll use.
But return rollers, RX18 and IR, electronics in the turret and maybe new turret rotaion motor and gun elevation motor are next up. Hope I will be done before spring :-)
Beachboy
And also swapped out the withe-cap motor with the black-cap for faster moving..
ID:	1367959   Click image for larger version
