RCU Forums - View Single Post - Could not do my maiden flight
Old 02-01-2010 | 01:01 PM
Bonified Wingnut's Avatar
Bonified Wingnut
Default RE: Could not do my maiden flight
Just work the throttle and servos through a fully charged battery or two. If you have no problems then try it. Make sure you do a range check. It is possible that your throttle wasn't all the way to idle..or the trims were set too high.-BW
