RCU Forums - View Single Post - WE NEED HELP WITH A WING SADDLE
Old 02-02-2010 | 02:31 PM
Mtthwacrss's Avatar
Mtthwacrss
Default RE: WE NEED HELP WITH A WING SADDLE
<span style="font-size: larger"><span style="font-family: Comic Sans MS"><span style="line-height: 115%">Thank you all for the help. I have re-drilled the holes and now the wing fits much better.<span style="mso-spacerun: yes"> </span>Just chock it up to having been too long since I last built a kit.<span style="mso-spacerun: yes"> </span>When I changed to the two pin mod I forgot that the pins move up and that caused the wing to set so low.<span style="mso-spacerun: yes"> </span>After re-drilling and a little sanding the wing is now setting in the saddle more like it should.<span style="mso-spacerun: yes"> </span>I will be using one of the gap filling methods you all mentioned.<span style="mso-spacerun: yes"> </span>This just shows why RCU is such a great site.<span style="mso-spacerun: yes"> </span>Years ago I would have had to wait until I could have gone to a hobby shop or to someone&rsquo;s house that knew what they are doing.<span style="mso-spacerun: yes"> </span><span style="mso-spacerun: yes"></span>Now we can put it out on line and get many different ideas and fixes.<span style="mso-spacerun: yes"> </span>Thanks again for all the help.<span style="mso-spacerun: yes"> </span>Also if you haven&rsquo;t checked out airfield models yet you should it has a lot of good info there thanks RCKen.</span></span></span></p>
