RCU Forums - View Single Post - Control line trainer
Old 02-03-2010 | 08:55 AM
Clean's Avatar
Clean
Default RE: Control line trainer
BustaHOR
Ok, so it's my own design but it's 25 size, made out of Aluminum and Coroplast, kills balloons like a mutha AND is fairly indestructable. It's not as flitty as the Manwin trainer and 25 size motors are easier to operate, use cheaper fuel and last longer than 049's. Controls are all exposed so you can keep an eye on them and there is basically nothing on the plane that if you break it (and by break I mean back over it with the car) you can't replace in half an hour tops. The part that takes longest is the motor mount and that's because it's cut out of Walmart Poly cuttingboard.
Thread on the BustaHOR http://spadworld.net/forum/viewtopic...light=bustahor
