RCU Forums - View Single Post - e-Neptuno
Thread: e-Neptuno
Old 02-04-2010 | 01:46 AM
  #37
Derek.Koopowitz
Default RE: e-Neptuno
Next is the gear...
Remember all the hardware is supplied. The only change/addition I made was to use a square nut as a spacer in the axle. You'll be able to see this in the pictures. I also lined the wheel pants with a rectangular piece of 1/32nd lite ply to give them some firmness where the axle passes through to ensure that the axle hole doesn't get worn out (bigger) on the fiberglass/carbon cloth. Getting the wheel pants and wheels mounted was a quick and easy process. The longest part was waiting for the Gorilla glue to dry on the lite ply pieces. Next is top bolt the landing gear to the landing gear plate. Everything is pre-drilled so there is no measuring of where the bolts go. Just put the bolts in the washers and then put a little Loctite on away you go...
As you can see from the pictures, everything comes out nice and clean.
1. All the parts for each wheel pant/wheel assembly
2. Completed assembly
3. Axle attached to the strut
4. Inside of assembly - you can see the additional square nut I used on the right hand side of the axle
5. Gear bolts and washers
6. A little dab of Loctite
7. Mounted gear - outside
8. Gear plate and bolts mounted
ID:	1371541   Click image for larger version
ID:	1371542   Click image for larger version
ID:	1371543   Click image for larger version
ID:	1371544   Click image for larger version
ID:	1371545   Click image for larger version
ID:	1371546   Click image for larger version
ID:	1371547   Click image for larger version
