RE: Brian Taylor OS2U Kingfisher Build
They seem to be somewhat functional. There are hardwood mounting points in the float and the plane so I guess they hold somewhat. That is probably why they only use a small pin in the drawings for the front strut as the strapping is probably intended to hold the float up pretty tight. I would imagine they keep everything from twisting at least.
