ORIGINAL: The_Shark
ORIGINAL: jmaxey51
ORIGINAL: The_Shark
im also running aluminum servo tray posts, belive it or not it does make the chassis even more ridgid.
i broke down and bought the aluminum stuff because when i bump started, i could see and feel the chassis flex a little, right by the engine, and i was worried about breaking my new engine and clutch, now its like trying to flex a piece of iron.
do you have a one piece engine mount? if not i would highly recommend one. if you have a picco or picco based engine it might be hard to find a one piece mount cheap because they have to have their own special mount because they have a weird crank case.
<br type="" />
no i dont, im running a Jammin jpx .21, i know the exhaust outlet was wierd.
oh you would have to get the King Heads one that is made for Picco Engines and its on the pricy side. i have the same engine and at the front of the case it hits the bar that connects the two sides.
<br type="_moz" />
