RE: First kit...am I crazy
Hi!
Brown colored micro balloons is best!
You use them with either 24 hour laminating (not epoxy glue) or polyester resin.
When mounting the piano wire braze onto the elevators it's best to grind the wire web shaped on a grinder. That way you do not get those blunt wire edges.
