RCU Forums - View Single Post - Wild Hare Electrics
Old 02-07-2010 | 07:13 PM
  #64
BTerry
My Feedback: (8)
Default RE: Wild Hare Electrics
I just returned from flying again and have a few thoughts.
KE mix requires ZERO aileron. I set up a variable mix on my Aurora 9 and ended up using 0% mix aileron to rudder. I am still working on the elevator settings and CG point, but I am getting close. This plane is simply locked in under any flight mode. It has a particular "howl" at high speed that is fun to hear as well. The APC prop really sings when it is moving. I did a bunch of full-throttle, low, inverted passes just to enjoy the harmony!
I set my timer for 8 minutes, and flew 8 min 24 sec. I recharged my battery and put 2443 mAh back into it. As this is a 3700 mAh pack I can probably safely fly about 10-11 minutes with a bit of reserve.
