RCU Forums - View Single Post - Another Skymaster Viper
Old 02-10-2010 | 03:54 AM
  #862
Ron v U
Default RE: Another Skymaster Viper
ORIGINAL: cgroen
Ron,
what have you done to make your fin removeable (if you have that), if using the second bolt that bolts the fin to the fuse, it is not possible to remove the fin when the thrusttube is installed ?
Hi Carsten,
I think i did almost the same as you.
There is the normal carbon tube on the rear of the fin and i had a aluminium tube in the front.
Then i pushed the fin on its place, drilled a hole in the fuselage into the alu tube for the extra bolt.
For the rear carbon tube i also drilled a hole in the fuselage.
Now i can easely screw/unscrew the two bolts when fin is on its place.
Regards Ron
ID:	1375566   Click image for larger version
