ORIGINAL: cgroen
Thanks Ron,
I have a carbon rod in the front (IIRC), but maybe the same idea can be used for me also.
I also drilled a hole just below the horz. stabilizer for the clamp-screw, that one is easy enough to get to, but I'm more worried of the front screw if that will be ok to screw that one into the carbon rod in mine ?
(Are there any ''meat'' around the front rod so the screw has something around it ?)
Carsten,
what i forgot to tell you, yes on my viper was enough meat around the front rod (epxoy and wood)
regards Ron
