RE: Modeltech Super Cub
Hi Tappa,
I was about to set up the aileron and flap servos and noted your comment on the position of the shaft to the rear rather than the leading edge as the instructions, even with a highlighted note, say to install. Question...had you tried it per the manual? I note also per Fizzy's post and picture the servo is toward the trailing edge, same as you stated. Were you able to sort out the flaps down together problem? I use a DX7 also.
John
