Best way to taper 1/4" elevators?
I use the center line method, draw a line in the center of the TE, then with the piece flat on the table ,with a 6 inch sanding block, sand from each side to the center line , holding the block at the desired angle takes a little practice but it works well, and will give you a centered taper .
Highlander
