RCU Forums - View Single Post - new with gasoline engines - help
Old 02-15-2010 | 12:10 PM
MinnFlyer's Avatar
MinnFlyer
Default RE: new with gasoline engines - help
You will need another battery pack to power the electronic ignition. You will also need a special stopper in your tank (Gasoline will disolve the supplied stopper)
You will also want to keep your radio gear at least 12" from the engine and do not use a metal pushrod to the throttle.
Aside from that, not much difference
