RE: os 46 AX Setting??
Is this a new engine? If so, then leave the low speed needle alone until you really feel it needs to be adjusted. Then the adjustment is done with the engine shut down and in very small increments. Turning it clockwise will close the valve (lean the low speed mixture), and counterclockwise will open it up (richen the low speed mixture). What I mean by small increments is like 1/8 of a turn.
CGr.
