 os 46 AX Setting?? >
os 46 AX Setting??
os 46 AX Setting??
Old 02-15-2010 | 12:35 PM
Default os 46 AX Setting??
What is the factory setting for the OS 46 AX?
Old 02-15-2010 | 12:56 PM
Default RE: os 46 AX Setting??
nrad2000
their is a web site for this.www.osengines.com this will tell you what you need to know.just download manual. i just double checked this is available at the site.
Old 02-15-2010 | 01:06 PM
I did download the manual. I couldn't find anything on the Low Needle (mixture) screw.
Old 02-15-2010 | 01:09 PM
I'll have to re-download it. seems like I got a partial one. ends at page 17.
Old 02-15-2010 | 01:25 PM
CGRetired's Avatar
Is this a new engine? If so, then leave the low speed needle alone until you really feel it needs to be adjusted. Then the adjustment is done with the engine shut down and in very small increments. Turning it clockwise will close the valve (lean the low speed mixture), and counterclockwise will open it up (richen the low speed mixture). What I mean by small increments is like 1/8 of a turn.
CGr.
Old 02-15-2010 | 02:01 PM
carrellh's Avatar
ORIGINAL: nrad2000
Find "Mixture Control Valve" in the PDF. It's on page 23 of the actual manual. In the 17 page PDF it's on 12 of 17.
