RCU Forums - View Single Post - Float length
Thread: Float length
Old 02-15-2010 | 05:10 PM
scale only 4 me's Avatar
scale only 4 me
My Feedback: (158)
Default RE: Float length
ORIGINAL: CowboyLifesaver
Hey, I just tell people what works instead of what most people think works. Seems there was just a conversation like this in a seaplanes thread. Puzzling
Let me rephrase. DO NOT PUT THE STEP OF THE FLOAT BEHIND THE CENTER OF GRAVITY AT ALL.
If I remember right in that thread you said cublover else helped you set up your plane. Go with what works for you, but, I respectfully disagree, That is like putting the mains on a tricycle gear set up infront of the CG,, the tail will drop. That step location could have the plane leaning on the rear of the floats all the time while taxing and will possibly allow the plane to rotate to quickly, this all depends on float desgn also. Although ith a flat bottom airfoil light wingloading plane you could get away with almost anything.
Gravity Storm,
Some more research docs to view
And so does Great Planes http://manuals.hobbico.com/gpm/gpmq1870-1874-manual.pdf (see page 12)
Seaplane supply http://www.seaplanesupply.com/faq.htm
