Hanger9 Cap 232 40
If anyone thinks of buying this airplane its pretty much a good one.
When you go to make up the pushrods though make sure you cut them about 3 1/2 inches shorter than what they are,the instruction say nothing about having to cut them but if you don't you go through the trouble of drilling and wraping the string and heat shrinking the the steel rod to the balsa pushrod only to find out..when you put them in the plane the balsa rod is hanging over you're servo's!
Also..they give you thick spring steel rod and they are impossible to z bend..they will break before you get it right,so i used regular "silver" pushod on the servo ends.
Other than that the Airplane is a nice one!
